Three way valve issues
15 Dec 2017
https://www.travisperkins.co.uk/Drayton-ZA3-679-3-3-Port-Valve-22mm/p/577344
Hi all
i have one of these in my house. i have a gravity fed boiler system with a tank in my airing cupboard. last weekend I fitted some new taps in the bath and before i did I turned off the cold water feed to the boiler, and also the boiler and control panel, using the red twist on the valve. now, I have found that my rads are getting warm when the hot water is heating up (not the central heating, the CH is turned off) but also it is warming up at times not corresponding to my control panel. so I am wondering if the fault is (a) the three way valve - the most likely option, and if so, is that easy for me to fix, or (b) faulty wiring because ive turned it on and off before tap installation (which would explain the timing issue)?
ive a few projects i am trying to do so i am going to write a couple of posts! TIA!
