Three Way Valve problem
4 Jan 2004
Could somebody help with a problematic three way valve?
The system has a Thorn Olympic boiler, a Grundfos pump and a Switchmaster three way valve.
I have recently drained the system to replace a blocked pipe. Everything worked ok beforehand but now I can't get any hot water when the heating is on.
If "heating and water" is selected the three way valve moves to "heating" only. If I move the valve manually to "heating and water" it just returns to "heating". If I then select "water only" on the panel the valve will go to "water".
Thanks in advance
Clink
Don't get me wrong - I'm no expert but...
what was blocking your pipe? could this now be jamming the valve?
Sorry if I'm stating the obvious!
Blocked with what? :eek: - Just curious...
Switchmaster is no longer made most of these were replaced a good few years ago best advice is drain system and change for Honeywell 3 way valve do note that the wiring is not the same as Switchmaster is a fully motorised valve and Honeywell is a spring return valve
Our central heating pipes are 8mm microbore and a feed pipe into one of the radiators was blocked with what looked like a lump of gravel. I had to cut the pipe and rod it out.
Thanks for the tip about the valve but it seems to have cured itself.
Clink
