Hi, any suggestions appreciated
After a leak in the supply pipe to my property (15mm copper/blue plastic coated) 1974 bungalow, I have a replacement water feed of the modern blue pipe which I think is 25mm. The only other thing that has changed is I have had the meter under the sink relocated to the boundary box in the pavement, the pipe from boundary to house is approx 9mtr in length, is goes back to 15mm plastic and through insubox entering wall to under sink. Last night I noticed a thump sound in pipes when sharply turning off either the hot or cold taps. It is only when you close the taps, is this what I'm assuming is called water hammer? Tonight I was gonna check the pipes for any contact points in the loft over bathroom as we were turning the water off in the street for a while when not in use because of the leak and running pipes clear of air each day for a while, is the thump due to the increased size of the pipe? Would an easy solution be to choke it back a bit at the pavement at the stop valve? We have always had ample pressure for the last 20yrs. TIA Neil
Update:just been tracking the noise and found it was loudest going back to the boiler, when you close the gate valve on the cold water boiler feed it goes away, when you open it...the noise comes back in that pipe, regardless of how much it is open, very bizarre.
