Good Morning! I've noticed recently that when the boiler comes on to heat the hot water, if the three-way valve has been to heating, that there is a thumping in the pipes as the hot water starts flowing. I've got a header tank in the loft so would that be causing air to get into the system?
Thanks again, David
Thanks again, David
