When the boiler starts in the morning,on water only after about 10 minutes a thumping sound starts. It sounds like it is coming from the hot water tank or above in the loft. The noise lasts for about 20-30 seconds then stops. This procedure occurs for about half an hour when the pump is timed to start for the radiators. The thumping seems to stop after this. I have drained down the system and added some descaleing solution(on advise)and bled the radiators. This seemed to quell the noise after about two days but never totally. It is now getting louder again. I have a baxi back boiler which is gas fired and the system (I am led to believe) is gravity fed. Being woke up at 4 in the morning is becoming tiresome,we are thinking about starting a family to have a genuine reason to be awake. Any suggestions will all be very warmly received.
