My bedroom radiator makes lound tick tick noise whenever heating is turned on and then it does it at intermittent intervals which match with the modulation happening on the boiler i.e. when boiler start firing up at higer pace making flow temperature to reach near cut off point and then start working on lower temperature again.
It's really difficult to diagnose the issue as I have held copper pipe with hand but tick tick noise still continues. Whole system is drained a few times for other work, inhibitor is added after last draining is done, air bleed valve is done and no air can be noticed on other radiators or Automatic air vents.
Please listen to the attached file (ignoring the background noise)
Any idea what can be causing it and further diagnosis or fix since it is affecting sleep
