First question here so be gentle with me!
I want to install a new oil tank to replace an elderly steel one. The new location will mean the tank outlet will be below the boiler pump (I estimate it's less than a foot). Although the boiler is around 35 years old it works ok and as we are not planning to stay here for ever I'd rather avoid replacing it ...for now at least.
As the tank outlet will be a bit below the boiler pump I've acquired a Tigerloop but a quick refresher inspection of the pump reveals it's a Danfoss BFP 21 L3. I take it that to fit the return to the Tigerloop I just remove the bypass plug next to the inlet port on the pump and connect the bypass in there?
TIA,
Steve
TIA,
Steve
