Hi just started tiling today in my bathroom, got myself some good BAL adhesive and I am tiling on to plaster board that has been put on with dot and dab. I have put up a vertical and horizontal batten and worked everything out so I dont end up with awkward tile sizes/cut anywhere, but I am not 100% sure how to work with the adhesive as it is ages since I did it before and dont even know if I knew correctly then.
It is very sodgy stuff and I am putting dolops of it in the area I need ie it is all different levels, so I scrape it down a little and then use the tilers trowel (6mm trowel) to get it level with lines but what am I aiming for, should I scrape it with this trowel so that the bits in between the teeth are almost cleaned off of adhesive so only the lines are left?
Or leave a total thin layer of plaster with the lines on top?
My thinking is it should be easier with fairly big tiles on a plasterboard surface but I am finding I am needing to fiddle too much getting them level, I need some tips.
The adhesive does not seem the easiest stuff to put on walls nicely, ie it needs playing with, I thought it would be eaier to apply like plaster.
When I hold the tiling trowel I hold it slightly angled and scarpe upwards, is this ok?
I am also tiling the shower area, should this area have the tile adhesive put on differently, I ask this as I read some where that there should be no voids left in the shower area, does this mean voids in the adhesive or voids as in cable/pipe channels?
If I could have spent a day with a tiler before hand I reckon I would have learnt so much especially how to put this stuff on.
Any advice and tips would really be appreciated.
