I need to use tile bead when tiling my bathroom window sill, do I have to leave the tile slightly above the window ledge to allow for the adhesive and then the tile that sits on top or does the tile go go flush to the height of the window sill and then the bead sits on top. As I thought if it goes flush to the height when you put the tile on it will be higher?
Hopefully this makes sense?,
Thanks.
Thanks.
