I have come up with a possible solution as how to tile over bathroom floor without increasing height over adjoining hall way, and would appreciate your thoughts.
The total height of 10mm heat insulating board, UFH wire, and tile will be about 24mm....so
Remove all floorboards (19mm).
Remove 5 mm from top of each joist.
Fix 2 x 2 battens to either side of joists, 25mm below reduced height top of joists, and fix 25mm strips of marine ply in between each joist, and screw firmly to battens, so tops of marine ply strips level with tops of reduced height joists so you have a flat floor.
Fix heat insulation boards with flex adhesive to wooden floor. Fix UFH wire to HIB's and tile over with flex adhesive and 10-12mm tiles,
According to my calcs, the finished tile floor will be a similar height to the existing floorboards in the adjoining hallway.....
Could possibly get away without reducing height of joists, taking into account hall will have carpet and underlay.
Thoughts would be appreciated....
