Today the wife was using HG mould spray in the bathroom, but some of the spray got onto the chrome tile trim and has caused staining is there anything i could try to remove the staining?
You have not said if the trim is chrome effect over plastic or chromed metal, if it is the latter then try using panel wipe that car sprayers use, if it is on chrome effect over plastic there may have been a chemical reaction which would be irreversible, didn't you read the packaging before use? If there is no indication on the packaging warning its application on certain materials it may be a good idea to contact the manufacturer to see what they have to say about the matter and maybe they will change the info on their packaging so no one else falls fail of this product.
