I have never done any kind of tiling to date and didn't do any research before hand (all my own fault ). I bought some ceramic tiles (40cm x 23cm) from a local tile shop to tile my bathroom and asked them to give me what I need to fix them. I was given 3 large tubs of adhesive and told to put the adhesive directly onto the tiles then stick them to the walls. The walls were all skimmed and smooth (as recommended by the tile shop) well in advance of me having to tile the bathroom. I did not prime the walls before hand. This tile shop was recommended to me by a lot of tradesmen who did various bits of work in my house so I made the mistake of trusting their advice/opinions.
Having put all the tiles on with the adhesive they supplied, I was ready to start grouting. It took me a week to fix the tiles on so by that time the wall that I started from was ready to have the spacers taken out. I took all the spacers out fine (some of them were very tight) on the first two walls, however when I got to the final two walls the tiles just started slipping off when I pulled a spacer out. Unforunately, I had a domino effect going on where one fell and hit some others and took those out (smashing a few on the way). With all the tiles that fell off, I noticed that the plaster on the wall was still clean and all the glue was on the tiles. I went to the tile shop and they said there must have been dust between the walls and the tiles - even though I am pretty sure I cleaned the walls thoroughly.
What I am left with now is two walls where some (around 10) tiles have fallin off and the spacers still between a lot of the tiles. Can anyone recommend what I should do next? Was it really dust that made the tiles not stick to the walls? Should I assume that all the tiles will drop off eventually or should I just check to see if there are any other loose ones? How do I fix the loose/fallen tiles back to the walls without them falling off again?
