Tiles flush with plaster - adhesive bed depth
DJM
4 Aug 2003
Surrey
I am updating the downstairs toilet and have discovered the original 1920's floor tiles below the carpet are in not bad condition and we want to keep them. The need a little tlc and I will ask about that in another thread. Bit, to keep the theme I have bought some matt black/white chequer mosaic tile to use as the basin splashback and run a border around the room.
I had a mad idea that it would be a good idea to make this border flush with the plaster which means removing the plaster back to brick. Now the issue is that means the depth brick to plaster would be about 20mm. As the mosaic tiles are very thin that would seem a far too large adhesive bed (and be expensive)
So is the idea mad, is there a better way of doing it, or should I just cut the old plaster out then fill with a 10mm plaster skim to have a 10mm adhesive bed?
