Hello to everyone on this forumn.
I've been reading a lot of the previous posts and have found them to all be very useful and sometimes quite funny.
To get down to buisness.
I'm about to tile a bathroom with a stand alone shower cubicle and am planning on going down the following route.
Around shower cubicle walls have been lined with Aquaboard on studs at max 450 ctrs. This was done to waterproof the walls, but mainly to allow power shower valve to be hidden in wall. rest of the walls beyond the shower cubicle have been/will be drylined with plasterboard on studs/ dot and dab. One wall is masonry wih cement backing plaster and gypsum skim coat all walls were previously tiled which have been removed and old adhesive scraped to remove any loose material.
Flooring has been replaced with 18mm thick exterior grade plywoood.
Bal shower tanking kit has been ordered to go round the power shower cubicle and what ever is left will be applied around the bath tub.
The shower cubicle is going to be tiled in either 50mm or 100mm square tumbled unfilled travertine tiles and the rest of the room using 200 or 300mm square tumbled travertine tiles. A 100mm high band of small mosiacs will be fitted around the room
I wish to use Bal adhesives and grouts (after listening to all the pro tilers recommending it on this site) and have looked at their literature but am unsure as to which adhesives would be best suited for the tile sizes and substrates that are being tiled over.
I was think that i should be using Bal single part flexible for the 100mm and upwards sized tiles and Bal mosiac fix for the mosiac band. with either Bal superflex wall grout or Bal microflex wall grout.
Does anybody have any recommendations on the products that have suggested or a more appropriate adhesive/grout combination.
I am also wishing to tile the floor in some larger travertine tiles with under tile heating at a latter date over the 18mm plywood. Which bal products should i be using.
I know the question has been very long winded but i thought i had better give you the full make-up of the room.
Thanks in advance.
Thanks in advance.
