Tiling a kitchen countertop
20 Apr 2014
I need to put down a wood base on a kitchen countertop before tiling it.I'm worried that plywood might de-laminate if it should get wet.Is there a better type of base I can use or will sealers and waterproof cements and grouting be adequate protection?.Also will the cement hold tiles to a formica top?
Ply would probably be OK, I used a double layer of chipboard glued and screwed together with the joints staggered for strength and give a coat of oil based paint to seal the surface, you can then tile the front edge or use a hardwood or whatever moulding. If done correctly no moisture should get to the board, make sure you use an acrylic waterproof grout as the surface will take quite a pounding over time.
I did mine about 7 years ago and still looks great.
ok i know it's a bit old but...... has anyone else tried to do this?? if so any hints/tips would be very welcome.
[edit] forgot to mention i'm going to be using mdf instead of chipboard - would that going to cause any problems??[/edit]
cheers
^^punt^^
update have been told NOT to use MDF as tiles don't stick (or something.?)
anyone else got any tips?
tatar
Exterior plywood do not de-laminated in the wet, I got one in my back garden and it's still the same with all this rain !
I mostly use damage or 2nd worktop which give you a big discount and turn it upside down ! (solid chipboard type)
hand't thought of the damaged worktop thing - good thining batman. :D
so have you ever seen/tiled a 'tiled worktop'? intrested in how to go about it, plus any possible drawbacks (i can think of food/liquid sitting on/staining the grout but that's about it - well the grout cracking Etc but i can't see any reason why not to have a tiled top)
You should have no problem at all.
Get a proper worktop grout which is design for food in kitchen, can't think of the name but got some sort if resin in it that will not stain.
