A number of questions requiring some help:
1) I am about to embark on building an alcove for a new shower enclosure. I am not certain to build the side wall (other two walls are existing masonary) out of plasterboard or plywood.
I will then need to tile it.
I'm tempted to use ply then seal it with 3 coats of PVA. Am I able to stick the tiles on with no more nails or similar and then use a waterproof grout....Or is this not a good idea and i should use plasterboard and tile cement?.
2) Can anyone give me advice on tiling a shower tray and the best method for ensuring a waterproof seal before i start to tile it.
3) Some advice on applying sealant so I don't end up with an unsightly lumpy mess of a seal/line
