hi
Our kitchen is being refitted. Ripping out the old tiles damaged the plaster board and we had the worst bits replaced with hard wall and multifinish.
We're having less tiles in the new kitchen but want the window sill and area behind the sink tiled.
The area behind the sink has now been painted - mist coat and 2 coats of Dulux endurance matt - while the window sill has not been touched as we always intended to tile it. The plaster on the sill has thoroughly dried now.
I'm after advice on tiling it as you guys were so helpful when I did my bathroom 2 years ago and the tiles are still up.
I used Bal Single Part Flexible & Microflex in the bathroom.
The kitchen area to be tiled is 0.5m^2 so a bag of cementitious adhesive seems a bit expensive for such a small area.
Can you recommend an adhesive and grout that will perform well in the kitchen and that is available in small bags. Also we are considering a coloured grout, either light grey or cream.
Will I need to seal the plaster on the window with an acrylic primer, I still have some Prime APD left from the bathroom job. Or can I tile straight onto it.
The tiles are small (200x200mm) ceramic ones.
Cheers!
Cheers!
