I have got my own ideas to insulate a 3x4 metre victorian style conservatory but as to whether in practice it ticks the boxes for been structurally correct is the question.Having already had quotes at around £9000 which is nowhere affordable at this present time, I'm hopeful of cutting the cost but not corners.
My intentions are to keep the materials lightweight so as not to overload the existing structure.
I wish to put in a flat ceiling using angle or T angle aluminuim section as a frame. Clad the underside with upvc hollow section decor panels. Put 300mm depth of fibreglass insulation on the top side. Reason for a flat ceiling is to take away a lot of unnecessary volume of air to heat.
On the roof I would fit treated wood tile battens screwed to the glazing bars. Then cover with waterproof tile undercloak. Fit 4 roof vents to minimise any condensation inside the roof space. Finally fix composite lightweight tiles, ridge tiles and flashing to the adjoining brick wall.
My main concern is the additional weight put on the glazing bars.
Any criticisms or pointers in the right direction would be most appreciated.
