tiling around a bath ?
13 May 2008
West Midlands
i want to tile around a bath , as im having a shower fitted , is it best to come off the bath with a full tile , or half a tile to allow some if the bath is not completely level
check the bath is secured to walls with brackets and is secured to floor as well,sealed to the wall with a quality silicone as well.
put a spirit line along bath and check level
take a tile place ontop off bath and walk it up the wall to the ceiling and see what size of cut you have.
if its a slither cut,then you will start off the bath with just over half a tile and again walk to ceiling and check cut,till your happy with the cuts at top and bottom.
you may want to look into tanking up the walls about 1metre,around bath area.
