I'm about to tile a wall which is having a mirror on it.
Is the normal method to fix the mirror first, then tile around?
Or tile first then fit the mirror on top of the tiles?
If it makes any difference it is a mirror that matches the vanity unit and has a shelf built in etc.
Also it is going on a wall between the window and the corner - it will only have 4cm on either side of it.
I'm thinking that tiling around it will be better but wanted to check first.
