tiling bath panel
9 Apr 2010
Birmingham
hi
its the first time that i am tiling a bathroom by myself , i would like to tile the sides of my bath and i wanted to know what is the best solution.
do i tile straight onto an acrylic panel or do i have a panel made specifically suitable for tiling onto?
im not sure howto go about it... is there any specific material other than the usual tiling equipment i purchase to carry out this task?
also what do i do about access.
hi
6hrs and no reply!!!
come on guys!!
when you say acrylic panel...?? what are you on/talking about? :rolleyes:
you want to use a solid timber background ideally plyboard if you want to tile onto it but its always a good idea to be able to get access under the bath so fix the board in a way you could gain access if needed use flexible tile adhesive and put flexi additive in the grout to make sure you prime the plyboard first with a good sealer/primer
We’ve been here several times before; using ply or any timber as a base for a tiled bath panel is not a good idea. If/when moisture gets into the back of the board it will warp & the tiles will fall off; use tile backer board.
