Tiling bathroom floor
29 Feb 2004
Lancashire
I have recently tiled my bathroom floor. As the floor is plasterboard paneling, I sealed the surface before tiling. Unfortunately, several days later, the tiles began to make a crunching sound and the grout began to crumble. As a novice I am not sure why this is happening. Please can you provide any help.
I should presume the "crunching noise" is the plaster board? ideally you should put marine ply down first screwed down every 8 inchesthen fix to this, the grout is coming out because the tiles are moving, soon they will be moving too. :cry:
Thanks for the reply.
The floor is actually chipboard and not plasterboard as I previously stated.
Would your answer still apply for chipboard ?
Thanks.
Sounds like you're not using enough floor adhesive.This is important when I say floor adhesive which allow for flexibility
