Tiling bathroom foor
4 Feb 2006
Hull
I am shortly going to tile my bathroom floor with porcerline tiles 48x53x10cm what is the minimum thickness of plywood needed
If you're overboarding floorboards, use 12mm ply screwed every 200mm. If replacing floorboards, I recommend using 25mm ply and add support (noggins) between joists under the joints in the ply. Ply should be exterior (WBP) grade.
No worries Dave. Check out the tiling sticky near the top of the floor tiling section for more details on adhesive etc. Good luck.
