Hello. I'm in the process of getting quotes to tile behind and around my wood burner. My question is in relation to the right approach and type of tradesperson to contact for the quotes, as given my wood burner is already installed, I'm guessing there are 2 options: 1) Tile around the legs - might not look as good but sounds easier 2) Remove the burner, tile under the legs and put burner back - could look better but sounds more complicated and expensive. Do people have experience of this, and would you recommend one option over the other? If Option 2, is this something a general home improvement/builder could do, or does it require a specialist to remove and replace the burner, then someone different to tile it? Thanks
