10mm Segment height. For ceramic and porcelain tile cutting. Clean cut. For wet or dry cutting.Expert quality blade designed with X-Tech Cutting technology for porcelain cutting as well as a range of tile and ceramic cutting applications. The continuous X-Tech rim blade offers a combination of...
www.toolstation.com
Might be able to undercut the riser so the tile goes under it.
www.toolstation.com
God bless Americans and their refusal to use safety guards...
#DarwinAwards.
Not sayin' that the angle grinder is the wrong tool, but please keep the guard on. And later in the video, the guy cuts a small hole. Why not just use a hole cutter?
