I want to reroof my double garage which currently has decayed fibre cement panels. I would like to use some sort of tiles if possible but would welcome any other suggestions for an aestheticlly pleasing roof. Problem is that it is only an 11.5 degree pitch.
minimum pitches for tiles.
rough guide.
30-35deg pitch plain tiles.
20 deg slates.
17-30 deg conc. interlocking.
there are a number of designs of interlocking tiles, only a few of which will allow for a shallow pitch. marley make a "wessex" which will go down to 15 deg with 100mm headlap.
redland regents go to 12.5 deg. or you could ply and felt under the tiles as to make an independant roof, the tiles would only really be for decoration.
For example, the Forticrete Centurion is spec.d down to 10'. BUT, in all cases, read the manufacturer's brochure for installation restrictions conditions and details. Then choose for yourself.
DON'T get discouraged by comments in these threads like 'sharp in-take of breath' (not picking on anyone - just pointing out that, to be really useful, advice aught to be qualified). Other things like allowing sags in breather membranes/roofing felt will greatly reduce the chance of water going through nail holes, as will using thicker battens to prevent tile nails puncturing the felt. Proper ventilation will also help dry out those wet battens!
The Building Regs guys are there to help. In some cases they may be a bit over zealous but the other day I was told of one case of a private Regs company certifying what the council would not.
After all, The Building Regs are down to acceptable levels of risk.
When you see a problem, think of a way around it...
yes and in this situation the correct method is to use torch on under felt, then counter batten then torch on over and around the counter battens before fitting the slate battens.
