Hi folks.
I'm ready for tiling and did a research for what adhesive to use on caberfloor P5.
My research lead to different result and I'm a bit confused now .
Most of cases suggest to use ply on top of caberfloor. But this is going to take my floor up to whatever the thickness of the ply would be plus the adhesive and the tile.
My problem is now that the kitchen floor (that used to be laminated), it's all in one with my open plan lounge (also with stupid laminated floor) and that would make a huge step between the 2 different floors and I would no fancy a ramp.
The ideal solution to this would be to tile on top of the water resistant cabelfloor but that has been not recommended because it take too long to cure?
Or do you know of any thin underlay? or a mesh? or something not too thick to use?
My wife in Italy she expecting a baby due next week or so. I will be flying on Tuesday and comeback in 2 weeks (so no one would be walking on that floor for 2 weeks . Would that be enough to cure completely?
I have spent most of the cash on this project and replacing the chipboard with marine ply would cost me quite a bit and add extra time to it.
My floor has lots of joist and noggins far more then recommended.
Caberfloor suggestions found on Page12 of: http://www.norbord.com/Euro_Caberboard_Tech_Guide.pdf
Guidance as to construction of
bases in respect to considerations
and timber bases is given in BS
5385: Part 3: 1989. Tiling onto
Caberfloor should be undertaken
only in joisted / fixed floor
constructions. Noggins should be
used between the joists at
300mm centres and the surface
provided for tiling should be
15mm exterior grade plywood
screwed to joists and noggins at
300mm centres. Existing boards
can therefore be overlaid with
15mm exterior grade plywood to
provide the necessary rigidity for
a tiled surface. Length of fixings
should be 2.5 times overall board
thickness. A tile adhesive is the
recommended bond material -
cement/sand mortars are not
recommended.
Excuse my English.
recommended.
Excuse my English.
