Tiling on Dry lining
29 Dec 2009
Wiltshire
I am about to start tiling my bathroom. currently the walls are dry lined plaster board. Is it beneficial to remove the painted paper, revealing just the plaster board itself or leave it on?
is it green plasterboard ? witch is needed in a bathroom tile straight on it unless shower area witch will need tanking !
When you say “remove the painted paper” do you mean wall paper that has been put over the plasterboard & then painted or has the plasterboard lining been painted directly over? Has the plasterboard been plaster skimmed?
You can tile directly onto plasterboard either plastered or unplastered with the right preparation but you can’t tile over wall paper. Do not attempt to remove the plasterboard lining paper, it will collapse in a heap on the floor.
As stated you must tank wet areas if you want it to last, what type & size tiles are you thinking of? I would advise a little more research before going any further, read the Tiling Sticky & Tiling Forum archive posts, lots of info in there that may prevent you making disastrous & potentially expensive mistakes.
