Tiling on plywood
19 Apr 2006
I am tiling a wall using mosaic tiles (the ones held together by a nylon sheet) as a border. The wall tiles are 4mm thicker than the mosaics. I was thinking of sticking the wall tiles onto 4mm plywood to make up the gap.
I was thinking of fixing the plywood to the wall using contact adhesive.
Is this a sensible thing to do?
Any advice welcome
There is a risk of moisture affecting the ply. Wedi board is available in 4mm thickness just fix with tile adhesive.
Jason
antharrison
an as our jase gave more good well known tiler tips away , here is mine , tile mosaics to board sections ,cleaning spills , leave to dry then affix to substrate with mudmix as said , then grout ..
