I am going to tile a bathroom floor and will be using Plywood as the base for the tiles.
Will plywood on its own (no floor board just straight onto the joists) be ok. The ply I am using is 22 mm thick?
Have had an offer of 18mm ply (not marine or water proof) for free. Enough to cover the area I am tiling. Would it be ok to use this and then put 6mm marine ply on top? I would stagger the joints again with the 6mm ply. Or would I be better off just buying 22m marine ply and be done with it?
