Tiling on to floor boards
9 Jun 2012
Hull
Is it possible to tile straight onto floor boards if I screw them all down? The reason I asked is I do not have the room underneath my UPVC front door to ply as well. I am tiling my hallway and removing all floor boards and replacing them with ply or chipboard would be too big of a job. :s
Help please !
P.s I thought about maybe using self levelling screed ?
In a word.................No.
Take up the floor boards and replace with 18mm ply.
Andy
the thinnest thing that will work is a backer board. 6mm. if you use no more ply you glue and screw this down, then use a flexi adhesive on top.
not sure if even this is too thick but might be worth a check.
Replace the f/boards with wbp ply 18-25 mm thick,.....seal underside and edges with primer ....screw down every 150mm onto joists( wats the joist spans)....tile away...
