tiling on undercoat plaster?
25 Aug 2006
Northumberland
Hi i have just removed a bath and now intend to replace it with a shower and tile from the tray to ceiling.The problem is that below where the bath was is now exposed brick.I have spoken to a tiler /plumber who i use and he recommends using pva on to the brick followed by a bonding coat of plaster.Leave for a day and then tile.Is this the way to go or should i use a one coat plaster?.I need to get the job done asap so the quickest solution would be best.
I would not normally tile on to a basecoat plaster and would not tile on to a plaster surface that still had moisture in it!
Could it be boarded out, if your in a hurry to tile?
