Tiling on WBP Plywood?
1 Jan 2008
Hi, I was hoping that somebody would have a suggestion for the following:
I am installing a new shower cubicle and have removed all the old tiles which has exposed the concrete wall. The wall is not the smoothest surface so I want to create a smooth surface to tile on.
I was considering putting WBP Plywood on the wall and then tiling on this. Would this be ok? I want to avoid using a thick material if possible.
Plasterboard it then tank the board with a tanking kit or you could use some aqua panel.
