Hi, im just about to start tiling my bathroom floor. I'm a bit confused by all the mixed messages about tiling over wooden floorboards, my floorboards are 600mm wide and run along the bathroom. they'r slightly creaky but not too bad. I need to know what i can get away with because i dont really want to lay 18mm ply and also 12mm tiles as there will be an arkward sized step. Also could anyone advise a good floor tile adhesive for porcelin tiles which is not too expensive? my bathroom only measures 2x2m. If i do end up using plywood, does it need to be primed with anything prior to spreading the adhesive.
p.s is flexible adhesive & grout worth buying? im not sure which brands are any good? thanks in advance.
Mark
Mark
