Hi all,
This is a bit of a novel, so you might want to grab a cuppa!!!
I am thinking about tiling and renewing my dated bathroom. However, I have several issues that I would appreciate some advice / guidance on.
Around the bath I have walls that are partially tiled and partially artexed. The tiled part forms the lower section of the wall. It is 4ft high from the floor and has a sand cement rendered background, which creates a small ledge that protrudes the above artexed section by 12-15mm. The artexed section of wall (which is in the form of a fine textured paint), runs from above the tiled part up to the ceiling. This wall is significantly out of plumb and level.
Due to the artex on the walls, I do not want to drill into them to batten them out, this in turn means I can’t use cement boards, tilebacker boards or any substrate that requires mechanical fixing. In addition to this, I am also quite limited on space.
However, what I was thinking of doing was to render over the artexed section of wall to a thickness of approx 15mm with plastering sand. Once that had dried, I would dot and dab moisture resistant plasterboard onto the wall to get it plumb and level. Then, use the Homelux tanking membrane to achieve a waterproof background, onto which I could tile.
At the moment this seems to be my only option but I would appreciate any assistance or alternatives you can offer.
