tiling onto asphalt
3 Apr 2006
i have an asphalt flat roof. in the summer it melts in the heat if you sit on a chair or leave something on it.
i want to tile this with porcelain (this is frost proof i believe?)
does anyone know how i can tile onto this asphalt flat roof?
you certainly can tile onto asphalt two methods fix with hot melt bitumen or the easiser way is to use pu adhesive (tile tech) from good roofing suppliers :idea: :)
but i have heard that i can only use "promenade" or "porous" tiles when tiling roofing grade asphalt. is this correct, or can i use any stone as long as i fix it with bitumin or the PU adhesive?
thanks
