Have tiled my downstairs WC using 600x300 porcelain tiles. I have some pipe work at low level that I need to box in then tile to match.
The boxing will be about1800mm long 200mm high and 70mm from the face of the wall.
Is it ok to use p5 for the boxing with 2x2 inside to support the 90º joint. Then tile onto it? I know p5 is controversial but as it’s well supported and not bearing any loads hoping it should be ok. Also it’s just a WC so no particularly wet areas.
Also should I still be using a tile adhesive or could I use some hybrid sealant instead to bond the tiles on to the boxing?
Any input appreciated
