Tiling onto Eggshell paint
14 Oct 2012
Hertfordshire
I want to tile on both sides of a corner in the kitchen behind the top of my freestanding cooker. The area is 1 square meter.
The main area have a thick coat of eggshell paint which I know would not absorb any moisture from the adhesive. Is the setting process done by hydraulic action, once water is added to a dry powder adhesive? Would that be better in my case than a pre-mixed version?
The other part of that area is very porous because I had to re-plaster that section. Perhaps to prevent too much moisture absorption from the adhesive would I need to seal that section with SBR or prime it with 50% paint 50% water?
Should a normal adhesive be sufficient to tile around the top of the cooker or would it have to be a heat resistant adhesive?
Thanks for your replies.
Im not a tiling expert but i would rub the eggshell back as much as possible to provide a good key for the new adhesive.
Fresh plaster should provide a good base for the new adhesive and i cant see the need for a heat resistant product.
I've tried rubbing down a small area with medium sand paper. The eggshell paint is very thick. The shine eventually comes off, it's very tough, and there is another coat (white) underneath which still makes it moisture proof. :confused:
As it's only 1m2, get a steamer and remove the paint and do the job well? Or a quicker fix is to score the paint loads.
If one can tile OVER ceramic tiles, I would have thought tiling onto eggshell paint would work.
Just use a batten for the first course of tiles.
