Your help please, I can almost answer my own question on tiling over chipboard (!!) - start again!
But because I have already come so far, I would appreciate your advice before making any more false starts and wasted material purchases.
I am raising the floor of a tiny downstairs cloakroom 110cm x 100cm that stepped down 120mm from the hallway. It will be tiled with 30cm sq granite tiles on flexible adhesive. The underfloor is concrete, rock solid. I wish I had just filled it in with concrete and screed but, on 'good' advice from a builder friend I have built a very robust exterior grade wooden 'eggbox' understructure with maxm 220mm between any joists or cross pieces. I was going to cover it with 18mm exterior ply, but was told that moisture resistant 22mm chipboard screwed and glued very close together, with all edges PVA'd would be solid enough for this small toilet area, and that using flexible tile adhesive there would be no movement. It does feel incredibly solid even before screwing it down. I have bought, cut and am ready to fix the chipboard down.
However ....... I have just read on this site and elsewhere that plywood is the only way. The MR chipboard was new to me and I believed what I had been told. However, if this could all lead to problems in the future, then now is the time to change approach. But if I use 18mm plywood I will have to pack it up by 4mm as I have already made the underframe to line up with the hall floor based on 22mm chipboard. The next size up plywood is 25mm which is too thick. And all this expense when concrete would have been more robust and a fraction of the cost.
From what I have described is there any way I can continue and use the chipboard - screwed & glued close and tight with sealed edges?
Many thanks
Many thanks
