Tiling over acoustic mat PLUS heating mat...
20 Oct 2022
Hello all.
I am planning to lay acoustic mats in my flat and need to manage the build-up so I don't lose too much room height.
Bathroom plan
• Existing wood sub-floor - 20MM
• Acoustic mat (stiff rubber composition) - 15MM
• Tile backer board - 6MM
• Heating mat - 2MM
• Adhesive bed - 6MM
• Porcelain tiles - 9MM
Total build-up is 58MM
Living room etc plan
• Insulation board - 6MM
• Heating mat - 2MM
• Engineered wood floor - 15MM
I have spoken with suppliers of finished floor, tiles, heating elements and acoustic mats. It is difficult to get a direct answer on the correct build-up.
The heating mat supplier said that the tile backer board should be STUCK DOWN on ply. If this is right, how thick should that ply be? Is it sufficient to be very thin just to stop movement of the tile floor? (I gather the difference between the floors is that the engineered wood will be a floating floor system whereas the tiles need to be fixed). Could I reduce the adhesive bed to accommodate some ply?
Thanks in advance!!
Any thoughts whatsoever on this? There must be a tiler on here somewhere!!
Too many variables in your Q & possibly in your flat, to give a reasonable answer.
Perhaps you understand that when you raise the FFL then all fixtures should also be raised - eg some shower trays are les than 58mm in height: the WC: Doors trimmed: skirtings etc.
