We're in the middle of gutting and redecorating our bathroom, after the previous house owners used standard plasterboard, didn't tank or seal it, and just used non waterproof grout/adhesive on the tiles.
We've had to rip out the disintegrated plasterboard, and the bottom stud wall frame, which was rotten, replace some of the floor, and then fit a new Vaal Concealed Thermostatic Mixer Valve, and cover with proper waterproof tile backing board.
However, the instructions that came with the shower valve were minimal, just 5 bullet points really, and a small diagram showing the water inlets & outlet, and another showing the components/parts list. It said to fit the valve 72mm-85mm deep, into the wall. I think we did about half way after checking. However, now we've put the tile backer over it, I tihnk it's protruding out to far, below is a pic without the face plate. Shouldn't the brass body be hidden behind the backing board? Having put a tile on the wall to see how far out they stick, I think it's going to stick out to much.
View media item 78462
We need to cut a hole in the tile, to fit around, but I think this should just be 2 holes for the taps, looking at this, it'll have to be a bigger cut out, shown below, to go around the whole thing wouldn't it?
View media item 78474
This is what it looks like with the face plate on:
View media item 78467View media item 78465
The main reason for setting it at the level we did, was because the water outlet seems very far in, even with a coupler attached, the shower hose connector just barely sits above the level of the tiles. If you look int he pic below, the fixing nut, that should screw against the tile wall is probably already going to be very tight in.
View media item 78464
Below is a quick diagram of how it's connected, probably not to scale, but gives a clue as to how it looks side on.
View media item 78473
Can anyone suggest any advice? Should I cut the tile backer again, and set the valve in deeper? If so, how can I then increase the length of the outlet, so it sits further out than it does currently?
