I’m planning on tiling over 18mm solid wood tongue and groove floorboards. There is a distance of 410mm between the centres of the joists under the floorboards.
I’m trying to keep additional height added to the floor to a minimum, so thinking of using hardie board.
My plan is to bed 6mm hardie board down onto a flexible cement based adhesive, I was thinking this one: https://www.toppstiles.co.uk/trade/.../excel-bond-super-flex-single-part-white-20kg
Then screw down and scrim the hardie board.
Then tile onto the hardie board using that same adhesive.
The kitchen tiles are 60cm by 30cm porcelain.
The bathroom tiles are 60cm by 60cm ceramic.
Would anyone be able to let me know if this sounds like it will work?
