I installed a sheet of stainless steel as a splashback behind the cooker. Its probably about 2m x 1.5m. However, I think it was poor grade steel, as it started to develop rust marks in the brushed finish.
I got a full refund from the place I bought it.. they didnt even argue, which suggested they knew they had a bad batch... I used no more nails type stuff to secure to the wall, and Im worried if I try to remove it, Ill probably pull down half the wall, or at least need to re render/plaster it.
Couldnt I simply tile over it?
Cheers
Cheers
