Tiling round or under WC bowl?
3 Dec 2005
Surrey
I'm shortly going to be tiling the floor of a small upstairs bathroom. I will be screwing 12mm WBP ply to the flloorboards and then the 13" square glazed porcelain tiles. Should I tile round the WC pedestal, or should I remove it, tile underneath and then re-fit it?
Thanks in advance for any advice.
John
You always get a better finish by lifting the pan, you will likely have to extend the cold feed and use an offset multikwik when you replace it, also worth getting a new dohnut washer as well
Jason
