Hi all
My shower room has a fake wall for the shower equipment, whose surface lines up level with the window recess shown on the left. In the original bathroom the thin white tiles had cracked where the frame met the window. The frame had been covered in thin board, and the window recess in plaster.
I have hacked back the window recess plaster and am about to fit 12mm aquapanel to straddle the two (flush) areas, hopefully to give a solid surface for tiling. I had been planning on screwing into the frame, and applying a few dot and dabs plus fixings into the window recess area. The recess area is just 100 x 17 cm.
However, I am concerned that the same stresses which cracked the original tiles will also crack the cement board, and then the tiles. Can anyone suggest anything better? eg....
1. Some kind of flexible dot/dab method?
2. Because the area is so small, just frame fix into a "high spot" of the brickwork without any dot/dab at all
3. Some other substrate, such as 12mm plywood and then good tanking? Seems a bit risky for a shower area ... though it is the wall of the shower holding the equipment, so dryest?
4. A thin layer of 4mm plywood between the frame/wall and the aquapanel? I suppose the panel still has to fix into the wall below.
NB. The tiles I'm using are 60x30 cm porcelain, 8mm thick, about 25Kg/m2 including grout and adhesive.
You can see that I am limited in terms of substrate thickness because it eats into the window surround area and will look "less odd" the thinner I keep it.
Thanks for any advice ...
Rich
Rich
