Tiling upto porch
Why did you remove the last board? Was it rocking or moving?
As you can see, the masonry between the joists is proud.
The board had a lip and loads of packing so it wasn't rocking, there wasn't anything wrong with it but we re plastered and had all the skirts changed.
The board was always dirty and it hard to clean as we use that door all the time so fancied having a layer of slate tiles there but don't know how to sort a base for them to go down on
I still dont understand why you removed the board when your intention was to tile over it?
Can you replace the board, firmly screwed down? You will then have a sub-floor for tiling or whatever.
Do you want a field of tile, or just a row at the door?
I removed it to take off the skirting board that went below that board either side. I never intended to tile it. It's was just an after thought.
The board that goes there is too thick really to tile on top off will leave a big step. Yeah just a row at the door is all I want
You cannot tile over what you show in the pic. You must have a firmly fixed base for the tile. All the boards must be on a level plane.
Perhaps go thro the tedious job of shaving off the proud masonry to give a level over the joist tops, then fix a board, and then prepare for tiling over.
Dont refix any skirting until your finished floorwork is complete.
