Tiling walls with ceiling different height
10 Oct 2019
Hi There
I am about to tile 3 walls around a bath and bathroom sink with 50 cm x 25 cm tiles.
The problem: The 2 side walls around bath are 8.5 cm higher (and slightly curved) than middle wall behind bath.
The simple option would be to tile middle wall with full height tiles which almost works out perfectly. The only problem here is that the side walls will then require an 8.5 cm tile at the top
The other option is to have almost half height tiles at bottom and top of middle wall which will work out better for side walls.
The only problem here is: more cuts plus there will be half a tile across middle of the rest of left wall to the door (if that makes sense).
Any thoughts on what might look best out of the two options?
Many thanks
Tiles along top of bath tend to govern tiles positions regards the height.
