I am tiling a bathroom and this has a small window with a window ledge 80cm(W) x 25cm(D). I am using 25cm x 20 plain white tiles.
I set the spacing of the wall tiles on the wall behind the bath but this has resulted in the spacing below the window to be offset in relation to the window ledge - i.e if I follow the same spacing onto the ledge this would mean the ledge tiling would not be symmetrical across the width of the ledge.
Would you ignore the wall spacing and set the ledge tiles symmetrical (start at the centre and work outward) or follow the wall tile spacing ?
U.
U.
