Tilt and Slide Patio Door - Draught
12 Nov 2005
Hull
I've had a look through the forum and can't find a topic that seems to cover this problem, namely that there's a roaring draught coming in round my tilt and slide patio door.
The draught comes in on the outermost edge where the handle is (IYSWIM). The seal is in tact but doesn't meet the frame enough to stop the draught.
Does anyone know if there's a way of adjusting the door to stop the icy blast coming through?
All help and advice greatly appreciated.
Fx
First thing to do is check the roller cams (the locks) on the door, with an allen key turn them so the dot or line faces into the room, this will pull the door tighter to the frame.
Good luck.....they're not the best! :cry:
