Timber Cladding - sarking?
7 May 2006
I have a small project to put up timber cladding in particular feather edge boards 150mm X 19mm.
The existing wall is brick and the plan is to screw vertical battens at 400mm centres across it then nail using stainless steel annular nails.
So my question ... I have read on the net that a vapour permeable membrane is used call sarking.
Is this normally only required if you are fixing the boards to a timber framed structure? or does it also apply to my brick building?
http://oak.arch.utas.edu.au/tbia/view_article.asp?articleID=203
What is the wall construction - single, double brick or cavity?
Vapour check membranes are for timber stud walls. And sarking is a term used for roofing felt.
I would avoid looking at foreign sites, as the methods/terms may not be relevent to UK construction
The wall is solid 9" brick.
Yeah the search I done on this site for 'sarking' brought back a number of references to roof sarking.
I suspect its similar to the type of product used on the timber cladding as a roof is really just a series of timber studs with a cladding applied(tiles/shingles).
The timber cladding is for aesthetic reason and not to provide weatherproofing/insulation. The solid brick wall is perfectly functional, just not very attractive.
In that case, as a 9" wall is deemed to have sufficient weather resistance, you do not need an additional membrane.
The wall will breathe naturally and resist any moisture which may get past the cladding.
